Mount and unmount database backups
You can mount a single or multiple data and log only backups if you want to access the files in the backup. You can either mount the backup to the same host where the backup was created or to a remote host having same type of Oracle and host configurations. If you have manually mounted the backups, you should manually unmount the backups after completing the operation. At any given instance, a backup of a database can be mounted to any one of the host. While performing an operation, you can mount only a single backup.
In a Flex ASM setup, you cannot perform mount operation on Leaf nodes if the cardinality is less than the number nodes in the RAC cluster. |
Mount a database backup
You should manually mount a database backup if you want to access the files in the backup.
What you will need
If you have an Automatic Storage Management (ASM) database instance in an NFS environment and want to mount the ASM backups, you should have added the ASM disk path /var/opt/snapcenter/sco/backup*/*/*/*/* to the existing path defined in the asm_diskstring parameter.
If you have an ASM database instance in an NFS environment and want to mount the ASM log backups as part of a recovery operation, you should have added the ASM disk path /var/opt/snapcenter/scu/clones/*/*_ to the existing path defined in the asm_diskstring parameter.
In the asm_diskstring parameter, you should configure AFD:* if you are using ASMFD or configure ORCL:* if you are using ASMLIB.
For information on how to edit the asm_diskstring parameter, see How to add disk paths to asm_diskstring. |
You should configure the ASM credentials and the ASM port if it differs from that of the source database host while mounting the backup.
If you want to mount to an alternate host, you must verify that the alternate host meets the following requirements:
Same UID and GID as that of the original host
Same Oracle version as that of the original host
Same OS distribution and version as that of the original host
For NVMe, NVMe util should be installed
You should ensure that the LUN is not mapped to the AIX host using iGroup consisting of mixed protocols iSCSI and FC. For more information, see Operation fails with error Unable to discover the device for LUN.
Steps
In the left navigation pane, click Resources, and then select the appropriate plug-in from the list.
In the Resources page, select either Database or Resource Group from the View list.
Select the database either from the database details view or from the resource group details view.
The database topology page is displayed.
From the Manage Copies view, select Backups either from the primary or secondary (mirrored or replicated) storage system.
Select the backup from the table, and then click
In the Mount backups page, select the host on which you want to mount the backup from the Choose the host to mount the backup drop-down list.
The mount path /var/opt/snapcenter/sco/backup_mount/backup_name/database_name is displayed.
If you are mounting the backup of an ASM database, the mount path +diskgroupname_SID_backupid is displayed.
Click Mount.
After you finish
You can run the following command to retrieve the information related to the mounted backup:
./sccli Get-SmBackup -BackupName backup_name -ListMountInfo -
If you have mounted an ASM database, you can run the following command to retrieve the information related to the mounted backup:
./sccli Get-Smbackup -BackupNamediskgroupname_SID_backupid-listmountinfo -
To retrieve the backup ID, run the following command:
./sccli Get-Smbackup-BackupNamebackup_nameThe information regarding the parameters that can be used with the command and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Command Reference Guide.
Unmount a database backup
You can manually unmount a mounted database backup when you no longer want to access files on the backup.
Steps
Select the backup that is mounted, and then click
Click OK.
