Overview of REST APIs
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
REST APIs can be used to perform several SnapCenter management operations. REST APIs are exposed through the Swagger web page.
You can access the Swagger web page available at https://<SnapCenter_IP_address_or_name>:<SnapCenter_port>/swagger/ to display the REST API documentation, as well as to manually issue an API call.
The plug-ins that support REST APIs are:
Plug-in for Microsoft SQL Server
Plug-in for SAP HANA Database
Custom Plug-ins
Plug-in for Oracle Database
