SnapCenter Software 5.0
Enable two-way SSL communication
You can enable two-way SSL communication to secure the mutual communication between SnapCenter Server and the plug-ins using PowerShell commands.
Before you begin
Execute the commands for all the plug-ins and the SMCore agent first and then for server.
Steps
  1. To enable the two-way SSL communication, run the following commands on the SnapCenter Server for the plug-ins, server, and for each of the agents for which the two-way SSL communication is required.
    > Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="true"} -HostName <Plugin_HostName>
    > Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="true"} -HostName localhost
    > Set-SmConfigSettings -Server -configSettings @{"EnableTwoWaySSL"="true"}
  2. Perform the IIS SnapCenter Application pool recycle operation by using the following command. > Restart-WebAppPool -Name "SnapCenter"
  3. For Windows plug-ins, restart the SMCore service by running the following PowerShell command:
    > Restart-Service -Name SnapManagerCoreService
Disable two-way SSL Communication
You can disable the two-way SSL communication using PowerShell commands.
About this task
  • Execute the commands for all the plug-ins and the SMCore agent first and then for server.
  • When you disable the two-way SSL communication, the CA certificate and its configuration are not removed.
  • To add a new host to SnapCenter Server, you must disable the two-way SSL for all plug-in hosts.
  • NLB and F5 are not supported.
Steps
  1. To disable the two-way SSL communication, run the following commands on SnapCenter Server for all the plug-in hosts and the SnapCenter host.
    > Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="false"} -HostName <Agent_HostName>
    > Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="false"} -HostName localhost
    > Set-SmConfigSettings -Server -configSettings @{"EnableTwoWaySSL"="false"}
