Enable two-way SSL communication on Windows host
You can enable two-way SSL communication to secure the mutual communication between SnapCenter Server on Windows host and the plug-ins using PowerShell commands.
Before you begin
Execute the commands for all the plug-ins and the SMCore agent first and then for server.
Steps
To enable the two-way SSL communication, run the following commands on the SnapCenter Server for the plug-ins, server, and for each of the agents for which the two-way SSL communication is required.
> Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="true"} -HostName <Plugin_HostName>> Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="true"} -HostName localhost> Set-SmConfigSettings -Server -configSettings @{"EnableTwoWaySSL"="true"} -
Perform the IIS SnapCenter Application pool recycle operation by using the following command.
> Restart-WebAppPool -Name "SnapCenter" -
For Windows plug-ins, restart the SMCore service by running the following PowerShell command:
> Restart-Service -Name SnapManagerCoreService
Disable two-way SSL Communication
You can disable the two-way SSL communication using PowerShell commands.
About this task
When you disable the two-way SSL communication, the CA certificate and its configuration are not removed.
To add a new host to SnapCenter Server, you must disable the two-way SSL for all plug-in hosts.
NLB and F5 are not supported.
Steps
To disable the two-way SSL communication, run the following commands on SnapCenter Server for all the plug-in hosts and the SnapCenter host.
> Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="false"} -HostName <Agent_HostName>> Set-SmConfigSettings -Agent -configSettings @{"EnableTwoWaySSL"="false"} -HostName localhost> Set-SmConfigSettings -Server -configSettings @{"EnableTwoWaySSL"="false"} -
