SnapCenter software
Storage systems and applications supported by SnapCenter
You should know the storage systems, applications, and databases supported by SnapCenter.
Supported storage systems
  • NetApp ONTAP 9.12.1 and later
  • Azure NetApp Files
  • Amazon FSx for NetApp ONTAP
    Supports non-volatile memory express (NVMe) over Transport Control Protocol (TCP).
    For information about Amazon FSx for NetApp ONTAP, see Amazon FSx for NetApp ONTAP documentation.
  • NetApp ASA r2 systems that are running NetApp ONTAP 9.16.1.
Supported applications and databases
SnapCenter supports protection of different applications and databases. For detailed information about the supported applications and databases, see NetApp Interoperability Matrix Tool.
SnapCenter supports protection of Oracle and Microsoft SQL workloads in VMware Cloud on Amazon Web Services (AWS) Software-Defined Data Center (SDDC) environments. Learn More.
