Storage systems and applications supported by SnapCenter
You should know the storage systems, applications, and databases supported by SnapCenter.
Supported storage systems
NetApp ONTAP 9.12.1 and later
Azure NetApp Files
Amazon FSx for NetApp ONTAP
Amazon FSx for NetApp ONTAP supports non-volatile memory express (NVMe) over Transport Control Protocol (TCP).
For information about Amazon FSx for NetApp ONTAP, see Amazon FSx for NetApp ONTAP documentation.
NetApp ASA r2 systems that are running NetApp ONTAP 9.16.1 and later
You should use ONTAP 9.17.1, if you are using SnapCenter Server 6.2 and SnapCenter plug-ins 6.2.
Supported applications and databases
SnapCenter supports protection of different applications and databases.
SnapCenter supports protection of Oracle and Microsoft SQL workloads in VMware Cloud on Amazon Web Services (AWS) Software-Defined Data Center (SDDC) environments. Learn More.
