Add-SmCredential
Register the credential with SnapCenter Server.
Syntax
Add-SmCredential [-Name] <String> [-Type] <SmAuthMode> [-SubscriptionId] <String> [-ClientSecret] <SecureString> [-TenantId] <String> [-ClientId] <String> [-InstanceName] <String> [-Credential] <PSCredential> [-EnableSudoPrevileges] <Boolean> [-Force] <>
Detailed Description
Register the credential with SnapCenter Server. The credentials can be for other plug-ins or for other NetApp cloud storage.
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
Specifies the name of the Credential Account. |
true |
true (ByPropertyName) |
Type |
Specifies the authentication mode. |
false |
SubscriptionId |
Specifies the Azure NetApp subscription ID. |
false |
ClientSecret |
Specifies the Azure NetApp client secret. |
false |
TenantId |
Specifies the Azure NetApp tenant ID. |
false |
ClientId |
Specifies the Azure NetApp client ID. |
false |
InstanceName |
false |
Credential |
true |
EnableSudoPrevileges |
false |
Force |
false |
Example 1: Create Credential
Add-SmCredential -Name RunAs1 -Type Windows -Credential $cred
Example 2: Create Azure Credential
Add-SmCredential -Name azure1 -Type AzureCredential -SubscriptionId 54967c34-6e2a-47fb-v43b-0f679710037d -ClientSecret d7c7656b-a07a-4es5-b19e-12376bdef493 -TenantId 6r21f23a-98b9-46fb-9d50-720ef604h328j -ClientId 984d66aa-0faf-jh34-8ca9-05lgs95fc92b
Note: Add-SmCredential with AzureCredential requires the following mandatory parameters SubscriptionId, ClientSecret, TenantId, and ClientId.
Example 2: Create AIX Credential
Add-SmCredential -Name RunAs2 -CredentialType AIX -Credential $cred
