SnapCenter 4.8 cmdlets
Add-SmCredential
Register the credential with SnapCenter Server.
Syntax
Add-SmCredential [-Name]  <String>  [-Type]  <SmAuthMode>  [-SubscriptionId]  <String>  [-ClientSecret]  <SecureString>  [-TenantId]  <String>  [-ClientId]  <String>  [-InstanceName]  <String>  [-Credential]  <PSCredential>  [-EnableSudoPrevileges]  <Boolean>  [-Force]  <>
Detailed Description
Register the credential with SnapCenter Server. The credentials can be for other plug-ins or for other NetApp cloud storage.
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the Credential Account.
true
true (ByPropertyName)
Type
Specifies the authentication mode.
false
SubscriptionId
Specifies the Azure NetApp subscription ID.
false
ClientSecret
Specifies the Azure NetApp client secret.
false
TenantId
Specifies the Azure NetApp tenant ID.
false
ClientId
Specifies the Azure NetApp client ID.
false
InstanceName
false
Credential
true
false
Force
false
Example 1: Create Credential
 Add-SmCredential -Name RunAs1 -Type Windows -Credential $cred
Example 2: Create Azure Credential
 Add-SmCredential -Name azure1 -Type AzureCredential -SubscriptionId 54967c34-6e2a-47fb-v43b-0f679710037d -ClientSecret d7c7656b-a07a-4es5-b19e-12376bdef493 -TenantId 6r21f23a-98b9-46fb-9d50-720ef604h328j -ClientId 984d66aa-0faf-jh34-8ca9-05lgs95fc92b
Note: Add-SmCredential with AzureCredential requires the following mandatory parameters SubscriptionId, ClientSecret, TenantId, and ClientId.
Example 2: Create AIX Credential
 Add-SmCredential -Name RunAs2 -CredentialType AIX -Credential $cred
