Add-SmGroup
Adds an AD group or local group to SnapCenter.
Syntax
Add-SmGroup [-Domain] <String> [-Group] <SmString> [-RoleNames] <SmString>
Detailed Description
Adds an Active Directory group or local group to SnapCenter.
| Name | Description | Required? | Pipeline Input | Default Value |
Domain |
The domain to which the group belongs to. Local group should skip this parameter. |
false |
true (ByPropertyName) |
Group |
Single group or list of groups belonging to the same domain or local host. |
true |
RoleNames |
Single or list of existing pre-canned or custom roles to which group should be added to. At least one role should be specified while adding the group. |
true |
Example 1: Adding a single group
Add-SmGroup -Group group1 -RoleNames role1,role2 -Domain domain1
Example 2: Adding multiple groups of same domain
Add-SmGroup -Group group1,group2 -RoleNames role1 -Domain domain1
Example 3: Adding local group
Add-SmGroup -Group LocalGroup1 -RoleNames role1
