SnapCenter 4.8 cmdlets
Add-SmGroup
Adds an AD group or local group to SnapCenter.
Syntax
Add-SmGroup [-Domain]  <String>  [-Group]  <SmString>  [-RoleNames]  <SmString>
Detailed Description
Adds an Active Directory group or local group to SnapCenter.
Name Description Required? Pipeline Input Default Value
Domain
The domain to which the group belongs to. Local group should skip this parameter.
false
true (ByPropertyName)
Group
Single group or list of groups belonging to the same domain or local host.
true
RoleNames
Single or list of existing pre-canned or custom roles to which group should be added to. At least one role should be specified while adding the group.
true
Example 1: Adding a single group
 Add-SmGroup -Group group1 -RoleNames role1,role2 -Domain domain1
Example 2: Adding multiple groups of same domain
 Add-SmGroup -Group group1,group2 -RoleNames role1 -Domain domain1
Example 3: Adding local group
 Add-SmGroup -Group LocalGroup1 -RoleNames role1
