Add-SmGroupToRole
Adds a group to an existing role.
Syntax
Add-SmGroupToRole [-Group] <SmString> [-RoleName] <String> [-Domain] <String>
Detailed Description
Adds a group to an existing role. A group is an active directory group that contains users, computers, and other groups. You can use groups to easily assign permissions to a set of users.
| Name | Description | Required? | Pipeline Input | Default Value |
Group |
Specifies the group you want to add to the role. |
true |
true (ByPropertyName) |
RoleName |
Specifies the name of the role to which you want to add a group. |
true |
Domain |
Specifies the domain to which the group belongs. |
false |
Example 1: Adding a group to a role
Add-SmGroupToRole -RoleName SnapCenterAdmin -Domain sddev -Group "Domain Admins"
This example syntax adds the Domain Admins group to the SnapCenterAdmin role.
SnapCenterAdmin
Domain Admins
