SnapCenter 5.0 cmdlets
Add-SmGroupToRole
Adds a group to an existing role.
Syntax
Add-SmGroupToRole [-Group]  <SmString>  [-RoleName]  <String>  [-Domain]  <String>
Detailed Description
Adds a group to an existing role. A group is an active directory group that contains users, computers, and other groups. You can use groups to easily assign permissions to a set of users.
Name Description Required? Pipeline Input Default Value
Group
Specifies the group you want to add to the role.
true
true (ByPropertyName)
RoleName
Specifies the name of the role to which you want to add a group.
true
Domain
Specifies the domain to which the group belongs.
false
Example 1: Adding a group to a role
 Add-SmGroupToRole -RoleName SnapCenterAdmin -Domain sddev -Group "Domain Admins"
This example syntax adds the Domain Admins group to the SnapCenterAdmin role.
SnapCenterAdmin
Domain Admins
