Add-SmResourceToUser
Adds resources to an existing user.
Syntax
Add-SmResourceToUser [-UserName] <String> [-ResourceNames] <String> [-ResourceType] <OperationAssignmentType> [-UserGroupObjectType] <SmUserGroupObjectType>
Detailed Description
Adds resources to an existing user. The resources can be a resource group, credential, host, policy, storage connection or plug-in.
| Name | Description | Required? | Pipeline Input | Default Value |
UserName |
Name of the domain\user. |
true |
true (ByPropertyName) |
ResourceNames |
Name of the resources to be assigned. You can use a comma to separate multiple resources. |
false |
ResourceType |
The type of resource being added to the user. Possible values are Credential, StorageConnection, Policy, Plugin, Host, and ResourceGroup. |
true |
UserGroupObjectType |
Specifies that the domain\username to which you are adding a resource is a group. |
false |
Example 1: Adding a host resource to an user
Add-SmResourceToUser -UserName sddev\administrator -ResourceNames clab-a13-13.sddev.mycompany.com -ResourceType Host
This example syntax assigns a host resource to the user.
Example 2: Adding a resource group to an user
Add-SmResourceToUser -UserName sddev\administrator -ResourceNames FinanceResourceGroup -ResourceType ResourceGroup
This example syntax assigns the FinanceResourceGroup resource group to the sddev\administrator user.
Example 3: Adding an credential to an user
Add-SmResourceToUser -UserName sddev\administrator -ResourceNames Cred_1 -ResourceType Credential
This example syntax assigns the Cred_1 credential resource to the sddev\administrator user.
Example 4: Adding a policy to an user
Add-SmResourceToUser -UserName sddev\administrator -ResourceNames testPol -ResourceType Policy
This example syntax assigns the testPol policy resource to the sddev\administrator user.
Example 5: Adding a storage connection to an user
Add-SmResourceToUser -UserName sddev\administrator -ResourceNames svm1 -ResourceType StorageConnection
This example syntax assigns the svm1 storage connection resource to the sddev\administrator user.
Example 6: Adding all the resources to an user
Add-SmResourceToUser -UserName sddev\administrator -ResourceType All
This example syntax assigns all the resources to the sddev\administrator user.
