SnapCenter cmdlets
Add-SmResourceToUser
Adds resources to an existing user.
Syntax
Add-SmResourceToUser [-UserName]  <String>  [-ResourceNames]  <String>  [-ResourceType]  <OperationAssignmentType>  [-UserGroupObjectType]  <SmUserGroupObjectType>
Detailed Description
Adds resources to an existing user. The resources can be a resource group, credential, host, policy, storage connection or plug-in.
Name Description Required? Pipeline Input Default Value
UserName
Name of the domain\user.
true
true (ByPropertyName)
ResourceNames
Name of the resources to be assigned. You can use a comma to separate multiple resources.
false
ResourceType
The type of resource being added to the user. Possible values are Credential, StorageConnection, Policy, Plugin, Host, and ResourceGroup.
true
UserGroupObjectType
Specifies that the domain\username to which you are adding a resource is a group.
false
Example 1: Adding a host resource to an user
 Add-SmResourceToUser -UserName sddev\administrator -ResourceNames clab-a13-13.sddev.mycompany.com -ResourceType Host
This example syntax assigns a host resource to the user.
Example 2: Adding a resource group to an user
 Add-SmResourceToUser -UserName sddev\administrator -ResourceNames FinanceResourceGroup -ResourceType ResourceGroup
This example syntax assigns the FinanceResourceGroup resource group to the sddev\administrator user.
Example 3: Adding an credential to an user
 Add-SmResourceToUser -UserName sddev\administrator -ResourceNames Cred_1 -ResourceType Credential
This example syntax assigns the Cred_1 credential resource to the sddev\administrator user.
Example 4: Adding a policy to an user
 Add-SmResourceToUser -UserName sddev\administrator -ResourceNames testPol -ResourceType Policy
This example syntax assigns the testPol policy resource to the sddev\administrator user.
Example 5: Adding a storage connection to an user
 Add-SmResourceToUser -UserName sddev\administrator -ResourceNames svm1 -ResourceType StorageConnection
This example syntax assigns the svm1 storage connection resource to the sddev\administrator user.
Example 6: Adding all the resources to an user
 Add-SmResourceToUser -UserName sddev\administrator -ResourceType All
This example syntax assigns all the resources to the sddev\administrator user.
