SnapCenter cmdlets
Add-SmUser
Adds AD users or local workgroup users to SnapCenter.
Syntax
Add-SmUser [-UserName]  <SmString>  [-Domain]  <String>  [-RoleNames]  <SmString>
Detailed Description
Adds Active Directory users or local workgroup users to SnapCenter.
Name Description Required? Pipeline Input Default Value
UserName
Single user or list of users belonging to the same domain or workgroup.
true
true (ByPropertyName)
Domain
Domain to which the user belongs to. Workgroup users should skip this parameter.
false
RoleNames
Single or list of existing pre-canned or custom roles to which the user should be added to. At least one role should be specified while adding the user.
true
Example 1: Adding a single user
 Add-SmUser -UserName user1 -RoleNames role1,role2 -Domain domain1
Example 2: Adding multiple users of the same domain
 Add-SmUser -UserName user1,user2 -RoleNames role1 -Domain domain1
Example 3: Adding workgroup user
 Add-SmUser -UserName LocalUser1 -RoleNames role1
