Add-SmUser
Adds AD users or local workgroup users to SnapCenter.
Syntax
Add-SmUser [-UserName] <SmString> [-Domain] <String> [-RoleNames] <SmString>
Detailed Description
Adds Active Directory users or local workgroup users to SnapCenter.
| Name | Description | Required? | Pipeline Input | Default Value |
UserName |
Single user or list of users belonging to the same domain or workgroup. |
true |
true (ByPropertyName) |
Domain |
Domain to which the user belongs to. Workgroup users should skip this parameter. |
false |
RoleNames |
Single or list of existing pre-canned or custom roles to which the user should be added to. At least one role should be specified while adding the user. |
true |
Example 1: Adding a single user
Add-SmUser -UserName user1 -RoleNames role1,role2 -Domain domain1
Example 2: Adding multiple users of the same domain
Add-SmUser -UserName user1,user2 -RoleNames role1 -Domain domain1
Example 3: Adding workgroup user
Add-SmUser -UserName LocalUser1 -RoleNames role1
