SnapCenter cmdlets
Disconnect-SdIscsiTarget
Terminates your session with the iSCSI target.
Syntax
Disconnect-SdIscsiTarget [-SessionIdentifier]  <String>  [-TargetNodeAddress]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
SessionIdentifier
Specifies the session identifier.
true
true (ByPropertyName)
TargetNodeAddress
Specifies the target node address.
true
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name of the computer or host on which the SnapCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine.
false
Example 1: Disconnecting from your iSCSI target session
 PS C:\> DisConnect-SdIscsiTarget -SessionIdentifier fffffa800762f020-4000013700000001 -TargetNodeAddress iqn.1992-08.com.netapp:sn.54053432d1f311e19455123478563412:vs.5
This example syntax disconnects you from your iSCSI target session.
