Disconnect-SdIscsiTarget
Terminates your session with the iSCSI target.
Syntax
Disconnect-SdIscsiTarget [-SessionIdentifier] <String> [-TargetNodeAddress] <String> [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
SessionIdentifier |
Specifies the session identifier. |
true |
true (ByPropertyName) |
TargetNodeAddress |
Specifies the target node address. |
true |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name of the computer or host on which the SnapCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine. |
false |
Example 1: Disconnecting from your iSCSI target session
PS C:\> DisConnect-SdIscsiTarget -SessionIdentifier fffffa800762f020-4000013700000001 -TargetNodeAddress iqn.1992-08.com.netapp:sn.54053432d1f311e19455123478563412:vs.5
This example syntax disconnects you from your iSCSI target session.
