SnapCenter 4.7 cmdlets
Get-SdAluaPaths
Lists all available ALUA-enabled disks and their state.
Syntax
Get-SdAluaPaths [-Paths]  <String[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Paths
Specifies the drive letter or mount point of the file system.
false
true (ByPropertyName)
Session
false
Host
Specifies the name of the host.
false
Example 1: Listing all ALUA enabled disks
 PS C:\> Get-SdAluaPaths
This example syntax lists information about all ALUA enabled disks.
