Get-SdAluaPaths
Lists all available ALUA-enabled disks and their state.
Syntax
Get-SdAluaPaths [-Paths] <String[]> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Paths |
Specifies the drive letter or mount point of the file system. |
false |
true (ByPropertyName) |
Session |
false |
Host |
Specifies the name of the host. |
false |
Example 1: Listing all ALUA enabled disks
PS C:\> Get-SdAluaPaths
This example syntax lists information about all ALUA enabled disks.
