Get-SdIscsiTarget
Enumerates iSCSI targets on a storage system.
Syntax
Get-SdIscsiTarget [-StorageSystemName] <String> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
StorageSystemName |
Specifies the name of the storage system for which you want to list iSCSI targets. |
true |
true (ByPropertyName) |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name of the computer or host on which the SanpCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine. |
false |
Example 1: Listing all iSCSI targets on a storage system
PS C:\> Get-SdIscsiTarget -StorageSystemName vs0
In this sample syntax, you get information about iSCSI targets on a specified storage system.
Example 2: Listing all iSCSI targets on a storage system
PS C:\> Get-SdIscsiTarget -StorageSystem 172.17.11.122
