SnapCenter cmdlets
Get-SdIscsiTarget
Enumerates iSCSI targets on a storage system.
Syntax
Get-SdIscsiTarget [-StorageSystemName]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
StorageSystemName
Specifies the name of the storage system for which you want to list iSCSI targets.
true
true (ByPropertyName)
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name of the computer or host on which the SanpCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine.
false
Example 1: Listing all iSCSI targets on a storage system
 PS C:\> Get-SdIscsiTarget -StorageSystemName vs0
In this sample syntax, you get information about iSCSI targets on a specified storage system.
Example 2: Listing all iSCSI targets on a storage system
 PS C:\> Get-SdIscsiTarget -StorageSystem 172.17.11.122
