SnapCenter 4.7 cmdlets
Get-SdLun
Gets information about the LUNs created on your storage system.
Syntax
Get-SdLun [-StorageSystem]  <String>  [-LunPath]  <String>  [-Session]  <String>  [-Host]  <String>  [-SerialNumber]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
StorageSystem
Specifies the name of the storage system on which your LUN is located.
true
true (ByPropertyName)
LunPath
Specifies the path of the LUN on your storage system.
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
SerialNumber
true
