Get-SdLun
Gets information about the LUNs created on your storage system.
Syntax
Get-SdLun [-StorageSystem] <String> [-LunPath] <String> [-Session] <String> [-Host] <String> [-SerialNumber] <String> [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
StorageSystem |
Specifies the name of the storage system on which your LUN is located. |
true |
true (ByPropertyName) |
LunPath |
Specifies the path of the LUN on your storage system. |
false |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
SerialNumber |
true |
