SnapCenter 4.7 cmdlets
Get-SdPortSet
Gets information about available portsets.
Syntax
Get-SdPortSet [-PortSetName]  <String>  [-StorageSystem]  <String>  [-GetLunMappings]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
PortSetName
Specifies the name of the portset about which you want to get information.
false
true (ByPropertyName)
StorageSystem
Specifies the name of the storage system on which your portset resides.
true
GetLunMappings
Indicates that you want to get information about the number of LUN mappings.
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
