      Get-SdPortSet
Gets information about available portsets.
Syntax
Get-SdPortSet [-PortSetName] <String> [-StorageSystem] <String> [-GetLunMappings] <> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
| PortSetName | Specifies the name of the portset about which you want to get information. | false | true (ByPropertyName) | |
| StorageSystem | Specifies the name of the storage system on which your portset resides. | true | true (ByPropertyName) | |
| GetLunMappings | Indicates that you want to get information about the number of LUN mappings. | false | true (ByPropertyName) | |
| Session | false | true (ByPropertyName) | ||
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) |
 PDFs
PDFs
