SnapCenter 4.7 cmdlets
Get-SdSnapMirrorPolicyRule
Gets the rules for managing Snapshot retention on the SnapVault secondary storage system.
Syntax
Get-SdSnapMirrorPolicyRule [-SourceStorageSystem]  <String>  [-SourceStorageSystemVolume]  <String>  [-DestinationStorageSystem]  <String>  [-DestinationStorageSystemVolume]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Gets the rules for managing Snapshot retention on the SnapVault secondary storage system. Related cmdlets: Set-SdSnapMirrorPolicyRule, Remove-SdSnapMirrorPolicyRule
Name Description Required? Pipeline Input Default Value
SourceStorageSystem
Specifies the primary storage system name containing the source volumes of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules. IP addresses are not supported.
true
true (ByValue, ByPropertyName)
Specifies the source volume of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules.
true
true (ByPropertyName)
Specifies the secondary storage system name containing the destination volumes of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules. IP addresses are not supported.
true
Specifies the destination volume of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Getting SnapMirror policy rule information from the policy for a SnapMirror relationship
 PS C:\> Get-SdSnapMirrorPolicyRule -SourceStorageSystem vs1 -SourceStorageSystemVolume src_vol -DestinationStorageSystem vs2 -DestinationStorageSystemVolume dest_vol01 -verbose
Get the SnapMirror policy rules from the policy on the specified relationship.
SnapLabel  : daily
NumberOfSnapsToKeep: 10
PreserveSnaps  :
PreserveSnapsSpecified : False
WarnThreshold  : 0
SnapMirrorPolicy   : snapvault_policy
SnapLabel  : weekly
NumberOfSnapsToKeep: 3
PreserveSnaps  :
WarnThreshold  : 2
SnapLabel  : mothly
NumberOfSnapsToKeep: 4
PreserveSnaps  :
WarnThreshold  : 3
The getting SnapMirror policy rules operation is successful.
