SnapCenter 4.7 cmdlets
Get-SdVM
Lists Hyper-V VMs and their attributes.
Syntax
Get-SdVM [-NoStorage]  <>  [-GetHyperVSnapshot]  <>  [-Name]  <String[]>  [-ComputerName]  <String[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Lists Hyper-V VMs and their attributes.Related cmdlets: Get-SdStorage
Name Description Required? Pipeline Input Default Value
NoStorage
Specifies that you do not want to get the Data ONTAP storage footprint of a share or mount.
false
false
GetHyperVSnapshot
Specifies that you want to get the Snapshot VHDs, the GUIDs associated with them, and the parent VHD.
false
false
Name
Specifies the name or GUID of the VM you want to get.
false
true (ByPropertyName)
ComputerName
Indicates the name of the Hyper-V server on which you want the VMs to be returned.
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Listing all HyperV VMs
 PS C:\> Get-SdVM
This example syntax lists all Hyper-V VMs and their attributes.
ComputerName Name Guid State Clustered VirtualDisks
clab-a8-7 vm1 94734822-f2a2-4ddb-9794-8139bc1efb0b Running false {\\vs1\share1\vm1\vm1.vhd}
clab-a8-8 vm2 d68f7d2a-31cd-437d-a435-e8757e730a01 Off true {\\vs2\share1\vm2\vm2.vhd}
Example 2: Listing all HyperV VMs on a specific HyperV server
 PS C:\> Get-SdVM -ComputerName "clab-a8-8"
This examples syntax lists all Hyper-V virtual machines on Hyper-V server clab-a8-8.
clab-a8-8 vm3 d68f7d2a-31cd-437d-a435-e8757e730a02 Off false {\\vs2\share2\vm3\vm3.vhd}
Example 3: Getting the attributes for a VM
 PS C:\> Get-SdVM -Name vm1 |fl
This example syntax gets the attributes of VM vm1.
Owner   : clab-a8-7
Guid: 94734822-f2a2-4ddb-9794-8139bc1efb0b
State   : Running
StorageType : NAS
SnapShotAttributes  : SnapDrive.Nsf.Interfaces.Virtualization.SnapShotAttributes
ConfigurationAttributes : SnapDrive.Nsf.Interfaces.Virtualization.VMConfigurationAttributes
HighlyAvailable : False
HAAttributes: SnapDrive.Nsf.Interfaces.Virtualization.HighAvailabilityAttributes
StorageFootPrints   : {HostResource : \\vs1_cifs\vol2_share StorageSystemResource : vs1:/vol/vol2/}
VirtualDisks: {\\vs1\share1\vm1\vm1.vhd}
Type: SDHyperv
Example 4: Showing the virtual disks on a VM
 PS C:\> (Get-SdVM sqltest-vm-01).VirtualDisks
This example syntax lists the virtual disks associated with VM sqltest-vm-01.
Type   : SDHyperv
VirtualDisk Location   : \\10.53.14.233\r2
VirtualDisk FullPath   : \\10.53.14.233\r2\sqltest-vm-01\Virtual Hard Disks\sqltest-vm-01.vhdx
StorageSystemResource  : sqltest-vsim1-bsd.sim.Company.com:/vol/vol2/
StorageSystemResource Type : SDStorageDir
HostResource   : \\10.53.14.233\r2
HostResource Type  : SDSMBShare
BootDisk   : True
Example 5: Showing all virtual disks and Snapshot copies on a VM
 PS C:\> (Get-SdVm -GetHyperVSnapshot vm_clus_smb4).VirtualDisks
This example syntax lists all the virtual disks including the Hyper-V Snapshot copies associated with VM vm_clus_smb4.
Type   : SDHyperv
VirtualDisk Location   : \\172.17.175.82\vol3_share
VirtualDisk FullPath   : \\172.17.175.82\vol3_share\vm_clus_smb4\Virtual Hard Disks\vm_clus_smb4.vhdx
StorageSystemResource  : vs2:/vol/vol3/
HostResource   : \\172.17.175.82\vol3_share
BootDisk   : True
Type   : SDHyperv
VirtualDisk FullPath   : \\172.17.175.82\vol3_share\vm_clus_smb4\Virtual Hard Disks\vm_clus_smb4_0F10EBD9-01F5-4546-9A99-49CF2EEAA755.avhdx
BootDisk   : True
