Get-SdVM
Lists Hyper-V VMs and their attributes.
Syntax
Get-SdVM [-NoStorage] <> [-GetHyperVSnapshot] <> [-Name] <String[]> [-ComputerName] <String[]> [-Session] <String> [-Host] <String>
Detailed Description
Lists Hyper-V VMs and their attributes.Related cmdlets: Get-SdStorage
| Name | Description | Required? | Pipeline Input | Default Value |
| NoStorage | Specifies that you do not want to get the Data ONTAP storage footprint of a share or mount. | false | false | |
| GetHyperVSnapshot | Specifies that you want to get the Snapshot VHDs, the GUIDs associated with them, and the parent VHD. | false | false | |
| Name | Specifies the name or GUID of the VM you want to get. | false | true (ByPropertyName) | |
| ComputerName | Indicates the name of the Hyper-V server on which you want the VMs to be returned. | false | true (ByPropertyName) | |
| Session | false | true (ByPropertyName) | ||
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) |
Example 1: Listing all HyperV VMs
PS C:\> Get-SdVM
This example syntax lists all Hyper-V VMs and their attributes.
ComputerName    Name    Guid                                    State      Clustered    VirtualDisks
clab-a8-7       vm1     94734822-f2a2-4ddb-9794-8139bc1efb0b    Running    false        {\\vs1\share1\vm1\vm1.vhd}
clab-a8-8       vm2     d68f7d2a-31cd-437d-a435-e8757e730a01    Off        true         {\\vs2\share1\vm2\vm2.vhd}
Example 2: Listing all HyperV VMs on a specific HyperV server
PS C:\> Get-SdVM -ComputerName "clab-a8-8"
This examples syntax lists all Hyper-V virtual machines on Hyper-V server clab-a8-8.
clab-a8-8       vm3     d68f7d2a-31cd-437d-a435-e8757e730a02    Off        false        {\\vs2\share2\vm3\vm3.vhd}
Example 3: Getting the attributes for a VM
PS C:\> Get-SdVM -Name vm1 |fl
This example syntax gets the attributes of VM vm1.
Owner   : clab-a8-7
Guid: 94734822-f2a2-4ddb-9794-8139bc1efb0b
State   : Running
StorageType : NAS
SnapShotAttributes  : SnapDrive.Nsf.Interfaces.Virtualization.SnapShotAttributes
ConfigurationAttributes : SnapDrive.Nsf.Interfaces.Virtualization.VMConfigurationAttributes
HighlyAvailable : False
HAAttributes: SnapDrive.Nsf.Interfaces.Virtualization.HighAvailabilityAttributes
StorageFootPrints   : {HostResource : \\vs1_cifs\vol2_share StorageSystemResource : vs1:/vol/vol2/}
VirtualDisks: {\\vs1\share1\vm1\vm1.vhd}
Type: SDHyperv
Example 4: Showing the virtual disks on a VM
PS C:\> (Get-SdVM sqltest-vm-01).VirtualDisks
This example syntax lists the virtual disks associated with VM sqltest-vm-01.
Name : sqltest-vm-01.vhdx Type : SDHyperv VirtualDisk Location : \\10.53.14.233\r2 VirtualDisk FullPath : \\10.53.14.233\r2\sqltest-vm-01\Virtual Hard Disks\sqltest-vm-01.vhdx StorageSystemResource : sqltest-vsim1-bsd.sim.Company.com:/vol/vol2/ StorageSystemResource Type : SDStorageDir HostResource : \\10.53.14.233\r2 HostResource Type : SDSMBShare BootDisk : True
Example 5: Showing all virtual disks and Snapshot copies on a VM
PS C:\> (Get-SdVm -GetHyperVSnapshot vm_clus_smb4).VirtualDisks
This example syntax lists all the virtual disks including the Hyper-V Snapshot copies associated with VM vm_clus_smb4.
Name : vm_clus_smb4.vhdx Type : SDHyperv VirtualDisk Location : \\172.17.175.82\vol3_share VirtualDisk FullPath : \\172.17.175.82\vol3_share\vm_clus_smb4\Virtual Hard Disks\vm_clus_smb4.vhdx StorageSystemResource : vs2:/vol/vol3/ StorageSystemResource Type : SDStorageDir HostResource : \\172.17.175.82\vol3_share HostResource Type : SDSMBShare BootDisk : True Name : vm_clus_smb4_0F10EBD9-01F5-4546-9A99-49CF2EEAA755.avhdx Type : SDHyperv VirtualDisk Location : \\172.17.175.82\vol3_share VirtualDisk FullPath : \\172.17.175.82\vol3_share\vm_clus_smb4\Virtual Hard Disks\vm_clus_smb4_0F10EBD9-01F5-4546-9A99-49CF2EEAA755.avhdx StorageSystemResource : vs2:/vol/vol3/ StorageSystemResource Type : SDStorageDir HostResource : \\172.17.175.82\vol3_share HostResource Type : SDSMBShare BootDisk : True
 PDFs
PDFs
