SnapCenter 4.7 cmdlets
Get-SdVolumeCloneSplit
Gets information about your clone volume splitting operation status.
Syntax
Get-SdVolumeCloneSplit [-JobId]  <String[]>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>  [-Path]  <Object[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
JobId
true
true (ByPropertyName)
StorageSystem
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Path
Specifies the clone splitting operation about which you want to retrieve status information.
true
