      Get-SdVolumeCloneSplit
Gets information about your clone volume splitting operation status.
Syntax
Get-SdVolumeCloneSplit [-JobId] <String[]> [-StorageSystem] <String> [-Session] <String> [-Host] <String> [-Path] <Object[]> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
| JobId | true | true (ByPropertyName) | ||
| StorageSystem | true | true (ByPropertyName) | ||
| Session | false | true (ByPropertyName) | ||
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) | |
| Path | Specifies the clone splitting operation about which you want to retrieve status information. | true | true (ByPropertyName) |
 PDFs
PDFs
