Get-SdVolumeCloneSplitEstimate
Estimates the amount of space you available, before you begin a clone splitting operation.
Syntax
Get-SdVolumeCloneSplitEstimate [-Path] <Object[]> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Path |
Specifies the path to the volume about which you want to retrieve a space estimate, before you begin a clone splitting operation. |
true |
true (ByPropertyName) |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
