SnapCenter 4.8 cmdlets
Get-SdVolumeCloneSplitEstimate
Estimates the amount of space you available, before you begin a clone splitting operation.
Syntax
Get-SdVolumeCloneSplitEstimate [-Path]  <Object[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Path
Specifies the path to the volume about which you want to retrieve a space estimate, before you begin a clone splitting operation.
true
true (ByPropertyName)
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
