Get-SmPluginPackage
Gets information about plug-in packages that have been uploaded for a specific custom plug-in.
Syntax
Get-SmPluginPackage [-PluginName] <String>
Detailed Description
Gets information about the plug-in packages that are uploaded for a specific custom plug-in.
| Name | Description | Required? | Pipeline Input | Default Value |
PluginName |
Specifies the name of the custom plug-in for which you want to determine the uploaded plug-ins. |
false |
false |
Example 1: Get information about a custom plugin package
Get-SmPluginPackage -PluginName DB2
This example syntax gets all uploaded package version information of the custom plug-in named DB2.
CustomPluginName: DB2
CustomPluginVersion : 1.0
CustomPluginType:
OsInfo : SMCoreContracts.SmOperatingSystemInfo
Resources : {SMCoreContracts.SmSCCustomResoureceType}
RequireFileSystemPlugin : False
UploadedFileName: DB2_1.0.zip
CustomPluginDisplayName : IBM DB2
CustomPluginVersion : 2.0
CustomPluginType:
UploadedFileName: DB2_2.0.zip
