Get-SmPolicy
Retrieves details about one or more policy.
Syntax
Get-SmPolicy [-PolicyName] <String> [-DatasetName] <String>
Detailed Description
Retrieves details about one or more policy. You can retrieve details about a specific policy or about all policies in a resource group.
| Name | Description | Required? | Pipeline Input | Default Value |
PolicyName |
Specifies the name of the policy for which you want details. |
false |
true (ByPropertyName) |
DatasetName |
Specifies a dataset. This parameter retrieves policy details for each policy in the dataset. |
false |
Example 1: Retrieving information about a policy
Get-SmPolicy -PolicyName "Full Backup with Replication"
This example syntax gets information about the specified policy.
ApplySnapvaultUpdate: True
ApplyRetention : True
RetentionCount : 2
RetentionDays : 0
ApplySnapMirrorUpdate : True
SnapVaultLabel : OneTime
MirrorVaultUpdateRetryCount : 7
AppPolicies : {}
Description :
PreScriptPath :
PreScriptArguments :
PostScriptPath :
PostScriptArguments :
ScriptTimeOut : 60000
DateModified: 6/10/2015 7:18:50 PM
DateCreated : 6/8/2015 11:03:07 PM
Schedule: SMCoreContracts.SmSchedule
PolicyType : Backup
PluginPolicyType: SMSQL
Name: Full Backup with Replication
Type:
Host:
UserName:
Passphrase :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel : 0
SmSqlBackupType: FullBackup
CopyOnlyBackup : False
CopyOnlyLogBackup : False
UtmType: None
UtmCounts : 7
UtmDays: 14
RunLiveDBCCBefore : False
RunLiveDBCCAfter : False
RetentionType :
TruncateLog: True
VerificationAfterBackup: False
TransLogMark :
TransLogDescription:
AGBackupType : UsePreferredBackupReplica
AGReplicaType : Primary
AGBackupPriorityMin: 1
AGBackupPriorityMax: 100
VerifyLogBackup: False
MaxDbConcurrentBackup : 35
CreateLogFolderSnapshot: True
DeleteLogFolderSnapshot: False
LogFolderSnapshotRetentionType :
LogFolderSnapshotCounts: 0
LogFolderSnapshotDays : 0
DeleteLogInShare : False
LogInShareRetentionType:
LogInShareCounts :
LogInShareDays :
CopyLogToShare : False
CopyLogToShareType :
VerifyPolicy : SMCoreContracts.SmVerificationPolicy
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted: False
Auth : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Example 2: Retrieving information for policies in a dataset
Get-SmPolicy -DatasetName DB_ON_I_S_DRIVE_ds
RetentionCount : 2
RetentionDays : 0
AppPolicies : {}
Description :
PreScriptPath :
PostScriptPath :
PolicyType : Backup
Type:
Host:
UserName:
Passphrase :
Deleted : False
IsClone : False
CloneLevel : 0
UtmType: None
UtmCounts : 7
UtmDays: 14
RetentionType :
TruncateLog: True
TransLogMark :
LogInShareCounts :
LogInShareDays :
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
GetSmPolicy for custom DB2 plugin
Get-SmPolicy -PolicyName SECONDARY_SNAPMIRROR
Custom plug-in DB2 policy with SnapMirror update enabled
BackupType : DATA
SchedulerType : None
RetentionCount : 24
RetentionDays : 0
VerificationEnabled : False
ApplySnapvaultUpdate: False
MirrorVaultUpdateRetryCount : 3
RetentionCount : 24
RetentionDays : 0
SnapVaultLabel :
AppPolicies : {}
DateCreated : 8/21/2016 4:23:20 PM
DateModified: 8/21/2016 4:23:20 PM
Description : testPolicy
PluginPolicyType: DB2
PolicyType : Backup
PostScriptPath :
PreScriptPath :
Schedules : {}
ScriptTimeOut : 60
Type:
Host:
UserName:
Passphrase :
Deleted : False
IsClone : False
CloneLevel : 0
Hosts : {}
PolicyId : 23
PluginName : DB2
PluginParams : SMCoreContracts.SmKeyValueCollection
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted : False
IsClone : False
CloneLevel : 0
Hosts: {}
