      Get-SmSchedule
Retrieves the schedule information. This command migrates data from SnapManager to SnapCenter plug-in for SQL Server. (This command works only if there are schedules present for SQL Server in SnapManager.)
Syntax
Get-SmSchedule [-HostName] <String> [-DisableCurrentGenSchedule] <> [-PluginCode] <PluginCode> [-SMSBaseUrl] <String>
Detailed Description
Retrieve the schedule information based on the host name and the plug-in code.
| Name | Description | Required? | Pipeline Input | Default Value |
| HostName | true | true (ByPropertyName) | ||
| DisableCurrentGenSchedule | false | true (ByPropertyName) | ||
| PluginCode | true | true (ByPropertyName) | ||
| SMSBaseUrl | false | true (ByPropertyName) |
- Example : Retrieve the schedule information based on the host name and the plug-in code. -
Get-SmSchedule -HostName windows2016 -PluginCode SCSQL
This example syntax retrieves the schedule information based on the host name and the plug-in code.
Schedule detail for the following Resources :
Windows2016\INSTANCE1\anu1
Schedule Information :
ScheduleStatus  : Enabled
Schedule: Backup Schedule
BackupType  : FullBackupAndLogBackup
TaskName: New2
ScheduleType: OneTime
SchedulerType   : WINDOWS
StartTime   : 9/13/2020 11:32:00 PM
EndTime :
DaysInterval:
DaysoftheMonth  :
DaysOfTheWeek   :
IntervalDuration:
MonthlyFrequency:
MonthsofTheYear :
RepeatTask_Every_Hour   :
RepeatTask_Every_Mins   :
SchedulerSQLInstance:
retention   : {SmPSSnapin.GetSmSchedule+Retention, SmPSSnapin.GetSmSchedule+Retention,
  SmPSSnapin.GetSmSchedule+Retention}
verificationsettings: SmPSSnapin.GetSmSchedule+VerificationSettings
hasVerificationSettings : False
Retention Information :
BackupType : DATA
RetentionCount : 7
RetentionDays  : 0
BackupType : LOG
RetentionCount : 0
RetentionDays  : 7
BackupType : LOG_SNAPSHOT
RetentionCount : 8
RetentionDays  : 0
TaskName: NEW6
StartTime   : 9/14/2020 4:52:00 AM
EndTime :
DaysInterval:
DaysoftheMonth  :
DaysOfTheWeek   :
IntervalDuration:
MonthlyFrequency:
MonthsofTheYear :
BackupType : DATA
RetentionCount : 7
RetentionDays  : 0
BackupType : LOG
RetentionCount : 0
RetentionDays  : 7
RetentionCount : 8
RetentionDays  : 0
TaskName: NEW7
EndTime :
DaysInterval:
DaysoftheMonth  :
DaysOfTheWeek   :
IntervalDuration:
MonthlyFrequency:
MonthsofTheYear :
BackupType : DATA
RetentionCount : 7
RetentionDays  : 0
BackupType : LOG
RetentionCount : 0
RetentionDays  : 7
RetentionCount : 8
RetentionDays  : 0
 PDFs
PDFs
