Get-SmSchedule
Retrieves the schedule information. This command migrates data from SnapManager to SnapCenter plug-in for SQL Server. (This command works only if there are schedules present for SQL Server in SnapManager.)
Syntax
Get-SmSchedule [-HostName] <String> [-DisableCurrentGenSchedule] <> [-PluginCode] <PluginCode> [-SMSBaseUrl] <String>
Detailed Description
Retrieve the schedule information based on the host name and the plug-in code.
| Name | Description | Required? | Pipeline Input | Default Value |
HostName |
true |
true (ByPropertyName) |
DisableCurrentGenSchedule |
false |
PluginCode |
true |
SMSBaseUrl |
false |
- Example : Retrieve the schedule information based on the host name and the plug-in code. -
Get-SmSchedule -HostName windows2016 -PluginCode SCSQL
This example syntax retrieves the schedule information based on the host name and the plug-in code.
Schedule detail for the following Resources :
Windows2016\INSTANCE1\anu1
Schedule Information :
ScheduleStatus : Enabled
Schedule: Backup Schedule
BackupType : FullBackupAndLogBackup
TaskName: New2
ScheduleType: OneTime
SchedulerType : WINDOWS
StartTime : 9/13/2020 11:32:00 PM
EndTime :
DaysInterval:
DaysoftheMonth :
DaysOfTheWeek :
IntervalDuration:
MonthlyFrequency:
MonthsofTheYear :
RepeatTask_Every_Hour :
RepeatTask_Every_Mins :
SchedulerSQLInstance:
retention : {SmPSSnapin.GetSmSchedule+Retention, SmPSSnapin.GetSmSchedule+Retention,
SmPSSnapin.GetSmSchedule+Retention}
verificationsettings: SmPSSnapin.GetSmSchedule+VerificationSettings
hasVerificationSettings : False
Retention Information :
BackupType : DATA
RetentionCount : 7
RetentionDays : 0
BackupType : LOG
RetentionCount : 0
RetentionDays : 7
BackupType : LOG_SNAPSHOT
RetentionCount : 8
RetentionDays : 0
TaskName: NEW6
StartTime : 9/14/2020 4:52:00 AM
EndTime :
DaysInterval:
DaysoftheMonth :
DaysOfTheWeek :
IntervalDuration:
MonthlyFrequency:
MonthsofTheYear :
BackupType : DATA
RetentionCount : 7
RetentionDays : 0
BackupType : LOG
RetentionCount : 0
RetentionDays : 7
RetentionCount : 8
RetentionDays : 0
TaskName: NEW7
EndTime :
DaysInterval:
DaysoftheMonth :
DaysOfTheWeek :
IntervalDuration:
MonthlyFrequency:
MonthsofTheYear :
BackupType : DATA
RetentionCount : 7
RetentionDays : 0
BackupType : LOG
RetentionCount : 0
RetentionDays : 7
RetentionCount : 8
RetentionDays : 0
