SnapCenter 4.7 cmdlets
Remove-SdIgroup
Removes an igroup from your storage system.
Syntax
Remove-SdIgroup [-Name]  <String>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the igroup you want to remove from your storage system.
true
true (ByPropertyName)
StorageSystem
Specifies the storage system from which you want to remove the igroup.
true
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Removing an igroup
 PS C:\> Remove-SdIgroup -Name IG_Demo -StorageSystem 172.17.168.13
This example syntax removes the a specific igroup from the specified storage system.
