Remove-SdIgroup
Removes an igroup from your storage system.
Syntax
Remove-SdIgroup [-Name] <String> [-StorageSystem] <String> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
Specifies the name of the igroup you want to remove from your storage system. |
true |
true (ByPropertyName) |
StorageSystem |
Specifies the storage system from which you want to remove the igroup. |
true |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Removing an igroup
PS C:\> Remove-SdIgroup -Name IG_Demo -StorageSystem 172.17.168.13
This example syntax removes the a specific igroup from the specified storage system.
