SnapCenter 4.7 cmdlets
Remove-SdSMBShare
Removes one or more SMB shares from your storage system.
Syntax
Remove-SdSMBShare [-Path]  <Object[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Removes one or more SMB shares from your storage system.This cmdlet is supported in clustered Data ONTAP 8.2 and later.
Name Description Required? Pipeline Input Default Value
Path
Specifies a comma-separated list of SMB shares.
true
true (ByPropertyName)
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Removing an SMB share
 PS C:\> Remove-SdSMBShare -Path \\JENKINS-CIFS\RemoveShare03 -Verbose
This example syntax removes SMB share "RemoveShare03" from your storage system.
Example 2: Removing multiple SMB shares
 PS C:\> Remove-SdSMBShare -Path \\JENKINS-CIFS\RemoveShare01,\\172.17.165.40\RemoveShare02 -Verbose
This example syntax removes SMB share "RemoveShare01," and "RemoveShare02" from the your storage system.
