Remove-SdSMBShare
Removes one or more SMB shares from your storage system.
Syntax
Remove-SdSMBShare [-Path] <Object[]> [-Session] <String> [-Host] <String>
Detailed Description
Removes one or more SMB shares from your storage system.This cmdlet is supported in clustered Data ONTAP 8.2 and later.
| Name | Description | Required? | Pipeline Input | Default Value |
Path |
Specifies a comma-separated list of SMB shares. |
true |
true (ByPropertyName) |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Removing an SMB share
PS C:\> Remove-SdSMBShare -Path \\JENKINS-CIFS\RemoveShare03 -Verbose
This example syntax removes SMB share "RemoveShare03" from your storage system.
Example 2: Removing multiple SMB shares
PS C:\> Remove-SdSMBShare -Path \\JENKINS-CIFS\RemoveShare01,\\172.17.165.40\RemoveShare02 -Verbose
This example syntax removes SMB share "RemoveShare01," and "RemoveShare02" from the your storage system.
