SnapCenter 4.7 cmdlets
Remove-SdStorage
Deletes a LUN and everything associated with it.
Syntax
Remove-SdStorage [-Path]  <String>  [-IgnoreVolumeMountPoint]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Path
Specifies you LUN share path using this format: :D
true
true (ByPropertyName)
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Deleting a LUN
 PS C:\> Remove-SdStorage -Path V:
This example syntax deletes the specified LUN.
