Remove-SdStorage
Deletes a LUN and everything associated with it.
Syntax
Remove-SdStorage [-Path] <String> [-IgnoreVolumeMountPoint] <> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Path |
Specifies you LUN share path using this format: :D |
true |
true (ByPropertyName) |
IgnoreVolumeMountPoint |
false |
Session |
Specifies the session ID from Open-SmConnection. |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Deleting a LUN
PS C:\> Remove-SdStorage -Path V:
This example syntax deletes the specified LUN.
