SnapCenter 4.7 cmdlets
Remove-SmClone
Removes an existing clone.
Syntax
Remove-SmClone [-CloneName]  <String>  [-PluginCode]  <PluginCode>  [-CloneAppObjectId]  <String>  [-Force]  <>  [-IsOracleAppVol]  <String>  [-PreCloneDeleteScriptPath]  <String>  [-UnMountCommands]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
CloneName
Specifies the name of the clone you want to remove.
false
false
PluginCode
Specifies the plug-in code for the plug-in host whose clone you want to remove.
true
false
CloneAppObjectId
Specifies the ID of the clone application object.
false
false
Force
Enables you to unregister a clone that has been removed outside of SnapCenter.
false
true (ByPropertyName)
IsOracleAppVol
This is a Oracle Application Volume specific parameter. It specifies the flag which enables to provide Pre-clone Deletion script and Unmount cmds to be run before Oracle Application Volume Clone Deletion.
false
This is an Oracle Application Volume specific parameter and IsOracleAppVol flag needs to be set to use this. It specifies absolute path of the executable script to be run before Clone deletion. The script should be located either at /var/opt/snapcenter/spl/scripts/ or any directory inside the path on the Oracle Plug-in host.
false
UnMountCommands
This is an Oracle Application Volume specific parameter and IsOracleAppVol flag needs to be set to use this. It specifies commands to unmount a file system from the Clone Host before Clone deletion. Enter multiple mount commands separated by semi colon (;).
false
Example 1: Removing a clone
 Remove-SmClone -CloneName payrollclone_dataset__clone__08-05-2015_14.41.11
This example syntax removes the specified clone.
Remove-SmClone
Are you sure you want to remove the clone?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"): y
Name: Deleting clone 'payrollclone_dataset__clone__08-05-2015_14.41.11'
StartTime   : 8/5/2015 2:47:14 PM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : False
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
Example 2: Removing a clone without the confirm dialogue
 Remove-SmClone -CloneName payrollclone_dataset__clone__08-05-2015_14.41.11 -Confirm:$false
EndTime :
IsCompleted : False
IsVisible   : False
IsScheduled : False
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
Example 3: Removing an Oracle Application Volume clone with PreCloneDeletion Script and Unmount Command
 Remove-SmClone -CloneName R8092776CF4V1_HNK2_com_appVol4__clone__3221_11-06-2021_05.57.33 -PluginCode SCO -IsOracleAppVol -PreCloneDeleteScriptPath "/var/opt/snapcenter/spl/scripts/preCloneDel.sh" -UnMountCommands "unmount /mnt/test"
This example syntax removes the specified Oracle Application Volume clone, PreCloneDeletion Script and Unmount Command are specified.
Remove-SmClone
			Name: Deleting clone 'R8092776CF4V1_HNK2_com_appVol4__clone__3221_11-06-2021_05.57.33'
			StartTime   : 11/6/2021 6:35:42 AM
			EndTime :
			IsCompleted : False
			IsVisible   : True
			IsScheduled : False
			Description :
			Status  : Queued
			Owner   :
			Error   :
			Priority: None
			Tasks   : {}
			ParentJobID : 0
			EventId : 0
			JobTypeId   : 7
			ApisJobKey  :
			ObjectId: 0
			PluginCode  : SCO
			PluginName  : SnapCenter Plug-in for Oracle Database
			HostId  : 0
			RoleId  :
			JobIds  : {}
Example 4: Removing an Oracle Application Volume clone
This example syntax removes the specified Oracle Application Volume clone.
Remove-SmClone
			EndTime :
			IsCompleted : False
			IsVisible   : True
			IsScheduled : False
			Description :
			Status  : Queued
			Owner   :
			Error   :
			Priority: None
			Tasks   : {}
			ParentJobID : 0
			EventId : 0
			JobTypeId   : 7
			ApisJobKey  :
			ObjectId: 0
			PluginCode  : SCO
			HostId  : 0
			RoleId  :
			JobIds  : {}
