SnapCenter 4.7 cmdlets
Remove-SmCloneJob
Removes an existing clone job.
Syntax
Remove-SmCloneJob [-CloneJobName]  <String>
Detailed Description
Removes an existing clone job based on the name of the clone job provided.
Name Description Required? Pipeline Input Default Value
CloneJobName
true
true (ByPropertyName)
- Example 1: Remove a clone job by clone job name -
 Remove-SmCloneJob -CloneJobName cl2
This example syntax removes a clone job based on the name of the clone job provided.
Remove-SmCloneJob
Are you sure you want to perform this action?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): Y
No clones associated with 'cl2' Resource Group.
Deleted Protection Group 'cl2' successfully.
Deleted clone policy 'cl2_ClonePolicy' successfully.
- Example 2: Removes a clone job by clone job name without a confirmation dialogue. -
 Remove-SmCloneJob -CloneJobName cl2 -Confirm:$false
