Remove-SmCloneJob
Removes an existing clone job.
Syntax
Remove-SmCloneJob [-CloneJobName] <String>
Detailed Description
Removes an existing clone job based on the name of the clone job provided.
Name | Description | Required? | Pipeline Input | Default Value |
CloneJobName |
true |
true (ByPropertyName) |
- Example 1: Remove a clone job by clone job name -
Remove-SmCloneJob -CloneJobName cl2
This example syntax removes a clone job based on the name of the clone job provided.
Remove-SmCloneJob
Are you sure you want to perform this action?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): Y
No clones associated with 'cl2' Resource Group.
Deleted Protection Group 'cl2' successfully.
Deleted clone policy 'cl2_ClonePolicy' successfully.
- Example 2: Removes a clone job by clone job name without a confirmation dialogue. -
Remove-SmCloneJob -CloneJobName cl2 -Confirm:$false
