SnapCenter 4.9 cmdlets
Refresh-SmBackup
Clears the stale backup entries from the SnapCenter Server.
Syntax
Refresh-SmBackup [-AppObjectList]  <String>  [-CleanupAllObjects]  <>  [-Auth]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
AppObjectList
false
true (ByPropertyName)
CleanupAllObjects
false
Auth
false
Example 1: Clears the stale backup entries from the SnapCenter Server for all resources
 Refresh-SmBackup -CleanupAllObjects
This example syntax clears the stale backup entries from the SnapCenter Server for all resources.
Example 2: Clears the stale backup entries from the SnapCenter Server by resource name
 Refresh-SmBackup -AppObjectList R708202074BV1\SQL2019\MDSL_DB3
This example syntax clears the stale backup entries from the SnapCenter Server by resource name.
