Refresh-SmBackup
Clears the stale backup entries from the SnapCenter Server.
Syntax
Refresh-SmBackup [-AppObjectList] <String> [-CleanupAllObjects] <> [-Auth] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
AppObjectList |
false |
true (ByPropertyName) |
CleanupAllObjects |
false |
Auth |
false |
Example 1: Clears the stale backup entries from the SnapCenter Server for all resources
Refresh-SmBackup -CleanupAllObjects
This example syntax clears the stale backup entries from the SnapCenter Server for all resources.
Example 2: Clears the stale backup entries from the SnapCenter Server by resource name
Refresh-SmBackup -AppObjectList R708202074BV1\SQL2019\MDSL_DB3
This example syntax clears the stale backup entries from the SnapCenter Server by resource name.
