SnapCenter 4.9 cmdlets
Set-SmRole
Modifies an existing role.
Syntax
Set-SmRole [-Name]  <String>  [-Description]  <String>  [-Permissions]  <String>  [-AssignedUsers]  <String>  [-AssignedGroups]  <String>  [-SharedObjects]  <>  [-DeleteSharedObjects]  <>
Detailed Description
Modifies an existing role. Enables you to modify assigned groups and users to the role, and to modify assigned SnapCenter resource permissions.
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the role you want to modify.
true
true (ByPropertyName)
Describes the role you want to modify.
false
Permissions
Specifies the permissions for the role: Example: host:read,create,delete,update;dataset:create,update,dashboard,allowUse the format [<SnapCenter Resource Name>:<permission1 name>,<permission2 name>,…​];[<SnapCenter Resource Name>…​]Permission settings for multiple SnapCenter resource names must be separated by ";"The SnapCenter resource name is DataSet, Policy, Backup, Host, StorageConnection, Clone, Provision, DashBoard, Restore, Reports, Discovery, Plugin_Installation or Migration.The permission name is create, read, update, delete or allow.
false
AssignedUsers
Specifies users to be assigned to the role: Example: domain1\user1,domain2\user2
false
AssignedGroups
Specifies groups to be assigned to the role: Example: domain1\group1,domain2\group2
false
SharedObjects
false
DeleteSharedObjects
false
Example 1: Modify a role and assigning permissions, users, and groups
 set-smrole -Name PayrollAppAdmin -Description "Manage payroll backup operations" -Permissions "DashBoard:allow;manageusergroup:allow;Plugin_Installation:read,update;DataSet:create,read,update,delete" -AssignedUsers "sddev\administrator" -AssignedGroups "mva\Administrators"
This example syntax modifies an existing role and assigns the specified permissions, users, and groups to the role.
Description : Manage payroll backup operations
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
