Set-SmRole
Creates a new role.
Syntax
Set-SmRole [-Name] <String> [-Description] <String> [-Permissions] <String> [-AssignedUsers] <String> [-AssignedGroups] <String> [-SharedObjects] <> [-DeleteSharedObjects] <>
Detailed Description
Creates a new role name. Enables you to assign groups and users to the role, and to assign SnapCenter resource permissions.
Name | Description | Required? | Pipeline Input | Default Value |
Name |
Specifies the name of the role you want to modify. |
true |
true (ByPropertyName) |
Description |
Describes the role you want to modify. |
false |
Permissions |
Specifies the permissions for the new role: Example: host:read,create,delete,update;dataset:create,update,dashboard,allowUse the format [<SnapCenter Resource Name>:<permission1 name>,<permission2 name>,…];[<SnapCenter Resource Name>…]Permission settings for multiple SnapCenter resource names must be separated by ";"The SnapCenter resource name is DataSet, Policy, Backup, Host, StorageConnection, Clone, Provision, DashBoard, Restore, Reports, Discovery, Plugin_Installation or Migration.The permission name is create, read, update, delete or allow. |
false |
AssignedUsers |
Specifies users to be assigned to the new role: Example: domain1\user1,domain2\user2 |
false |
AssignedGroups |
Specifies groups to be assigned to the new role: Example: domain1\group1,domain2\group2 |
false |
SharedObjects |
false |
DeleteSharedObjects |
false |
Example 1: Creating a new role and assigning permissions, users, and groups
set-smrole -Name PayrollAppAdmin -Description "Manage payroll backup operations" -Permissions "DashBoard:allow;DataSet:create,read,update,delete" -AssignedUsers "sddev\administrator" -AssignedGroups "mva\Administrators"
This example syntax creates a new role and assigns the specified permissions, users, and groups to the role.
Description : Manage payroll backup operations Name: PayrollAppAdmin Type: Id : Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0
